Help decide
Old Oct 30, 2009 | 05:55 PM
Michael Halo's Avatar
you can find a used block for $200 or so there new at sdpc for like $675 just do that but if your goals are 12s and if you can get it whit your 5.3 then why go true all that bull ****....
Old Oct 30, 2009 | 06:04 PM
dirt track racer 81's Avatar
you could bore and stroke your 5.3 to a 383ci.
Old Oct 30, 2009 | 08:11 PM
silveradokidd_4518's Avatar
this is true as well...
Old Oct 30, 2009 | 08:18 PM
a 383 would be more of torque motor considering it will have a 4.0 stroke crank.
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't use that block either. Probably wouldn't have much faith in that crank either. With your goals, I'd say go .030 over on a 6.0, for the 370. Good head/cam/converter package. Spray it if you have to.
Old Oct 30, 2009 | 10:48 PM
Bowtie03's Avatar
If your goals are 12s and if you can get it whit your 5.3 then why go true all that bull ****....
I'm sure the least expensive route would be to go with the 6.0 and different block. I want to stay N/A and I don't think I could get my ECSB with the 5.3 to 12's without spray. I don't have a budget but I looked at the prices on the stroker kits for the 5.3 and they are way more than I want to spend on just bottom end.
I'm having trouble finding a good used block (6.0) in my area. They're just not here for what I can see. I will have the crank checked before I use it.
Any ideas what heads/cam to get me to my goals with the 6.0?
Know any places to find a good shortblock?
Thanks
Old Oct 30, 2009 | 11:05 PM
how much are you wanting to spend
Old Oct 30, 2009 | 11:20 PM
Bowtie03's Avatar
Well as far as cam, I got a Comp xr275hr that was never opened at all, its still in the cellophane. They told me they would take it back and grind me a custom grind for trade of the shelf cam. So I can save some money right there. Got some parts to sell so I will buy as I go so, whatcha thinking?
Old Oct 30, 2009 | 11:23 PM
i mean as is just a couple hundred bucks or 1-2-3k?
Old Oct 30, 2009 | 11:53 PM
Bowtie03's Avatar
I would probably allow 3k total for engine.
