Help with build: 243s + TVS1900
Old Jul 19, 2011 | 09:44 PM
jiar577's Avatar
Default Help with build: 243s + TVS1900
Heads need to be milled to increase CR, I know most guys mill around 0.030 to get compression back to stock levels.
1. Any fitment issues w the blower when milling the heads?
2. What CR do I want with a blower and how much to mill? trever1t was around 9.9:1 and worked great.
More than anything I want to know if there would be any fitment issues.
Plan to run 10psi
Full specs in sig
Old Jul 19, 2011 | 09:54 PM
quicksilverado's Avatar
Milling the heads is not a good idea with forced induction. You will make the head decks thinner and they will be more prone to lift.
Old Jul 19, 2011 | 10:15 PM
jiar577's Avatar
Good think I asked then, thanks man.
Old Jul 20, 2011 | 02:18 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't worry at all about lifting heads at 10 psi, even with a thinner deck. We're only taking about .030" here. How many .030 over 6.0 liters (370 CID) are out there running blowers and turbos, making big power?
Old Jul 20, 2011 | 09:05 AM
You are talking about .030 over cylinder walls to make a 6.0 into a 370. He is talking about taking .030 of a cylinder head deck, which is a lot of material.
Old Jul 20, 2011 | 12:15 PM
swift700's Avatar
I milled mine .015 and there were no fitment issues. Where you might run into problems would be with blower-to-valley cover clearance, but I'd give it a go. I wish someone made thicker intake manifold gaskets.
I'm running 9.9:1 and have no issues at 10psi.
Old Jul 20, 2011 | 12:24 PM
True, but we're only talking about 10 psi here, which is not alot of boost IMO.
Old Jul 20, 2011 | 05:18 PM
jiar577's Avatar
Fitment is my concern, .015 isn't enough to bump CR in my set up. I guess I'll just throw the blower over the stock heads and be done lol
Thanks
zblee
Nov 11, 2015 12:41 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
brandon6.0
Sep 25, 2015 11:58 PM
