Help
So im building a ly6 6.0 bored .020 over stock crank and rods and was wondering if I had to have it balanced its a daily driver probably only see the track a couple times a year I tried to search this but didn't really come up with any thing to answer this so any help will be greatly appreciated thanks -JOE
Your crankshaft bobweights would be unbalanced with the pistons. It might cause vibration. Vibration causes premature wear of bearings and pistons and is generally hard on everything. Your chances of throwing a rod is greatly increased at higher rpm's. Bad harmonics kill engines.
I don't know because it was all included in my machining costs. Call an engine builder and find out. I'll guarantee it's a lot cheaper than a new engine and you'll be able to spin it to the moon.
