Which heads for this truck?
Old Dec 2, 2006 | 11:33 PM
dbs1's Avatar
Default Which heads for this truck?
After debating selling my truck, it appears I may just hang onto it for awhile. I've had to pull the engine due to a shoddy job on the last rebuild, and while having it apart thought I'd do a few things to it.
This truck is a 01 gmc C3 awd with an LQ4 engine. It's had forged pistons, some mild port work on the stock heads, 1.85 rockers, and all other internals stock, using a single turbo setup, with a best of 12.3 @ 109.
I'm still not wanting to go full race, and hence I've gone back to a tighter convertor (2000) for drivability, and tranny longevity. We're going to bump up from the current 8.0 cr to a 9.0 cr, and use better rings and bearings, and I'm debating using some better heads to get into the 11's.
The first question I'm sure is budget, which with a few camaros eating my wallet is somewhat tight for this truck, but at the same time while I've got it apart and in no particular hurry I'm of a mind to spend some $ to imrove what we'e got.
Can we make a significant improvement for $1500 on some dart 205cc heads (not looking to go too big on the street), or is it worth the extra $ for some afr heads. Others? Gain vs $ spent? The shop doing the work has some patriot heads, but tells me they have found them to be worth about 5 hp less than stock.
Any thoughts-experience with this setup? Thx!
Old Dec 3, 2006 | 12:21 AM
onebadrubi's Avatar
five richard at WCCH, he is a sponsor, a call. He has a killer stage 2 port for under 1500. Assmbled!!
Old Dec 3, 2006 | 12:50 AM
02sierraz71_5.3's Avatar
L92/l76 for the money it cant be beat new intake, heads, fuel for 1500 and the priliminary results are very promising the stock heads flow over 300 @.500 and make great tq for such big ports
Old Dec 3, 2006 | 08:59 AM
L92's looks promising @ much lower price.
Old Dec 3, 2006 | 10:11 AM
yurs78's Avatar
Aren't there some issues with the bore centers being different creating some valve clearance issues? They have amazing potential but it would seem that you just won't get the max out of them because of alignment? Also aren't the intakes different too if you switch to those heads?
I'm no expert, but from the few things I've read you can get them to work well but there is a bit of "massaging" involved. So it's not a cut and paste process.
Old Dec 3, 2006 | 12:11 PM
The only issues with Quality Ive heard about are the new 6.2 blocks
have to have a new intake but for 1500 you get the heads and an intake that outflows the ls6, if I remember right you get the rails too.
Old Dec 4, 2006 | 10:44 AM
dbs1's Avatar
I'd like some more info on the L92 heads. I see Scroggin Dickey has the intake, but have not seen where to buy the heads or the cost? Flow or fit info? Thx!
Old Dec 4, 2006 | 12:16 PM
tahoe's Avatar
Where can all this L92 stuff be bought, sounds wery intresting!
Heads, intake, fuelrail, Injectors?
Br//
Old Dec 4, 2006 | 01:26 PM
onebadrubi's Avatar
what other fabrications have to be done besides the intake(comes with injectors), heads and throttle body?
The_W
Oct 28, 2015 09:00 PM
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
