Head thickness?
Old Jun 23, 2006 | 01:45 PM
Default Head thickness?
Does anyone know the stock thickness on 5.3 heads?I was curious to see how much has been milled off a set of heads my cousin is installing on his truck.
Old Jun 23, 2006 | 05:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Most I have seen is .05 and they were going on an LS1 with fly cut pistons.
Old Jun 23, 2006 | 10:21 PM
Richard@WCCH's Avatar
FormerVendor
Measuring from the valve cover rail to the deck surface, a stock unmilled head will be 4.750" +or- .003"
Good luck.
Richard
Old Jun 24, 2006 | 08:40 AM
GoatChs's Avatar
Good luck. Richard
I was about to ask if the valve cover rail and deck surface are on a parallel plane, but I'm guessing that as you indicated no measurement point that it is.
Old Jun 25, 2006 | 12:43 PM
FormerVendor
That is correct. The valve cover is parallel to the deck surface.
Good luck.
Richard
GMCtrk
Dec 18, 2015 04:47 PM
livefast1
Sep 25, 2015 07:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
BennyB
Aug 1, 2015 08:48 AM
therock
Jul 25, 2015 09:23 AM
