Head Swap Sucks!!!! Plus Question.
Old Oct 6, 2007 | 07:56 PM
TouchOfEvil04's Avatar
Default Head Swap Sucks!!!! Plus Question.
Ok well so far the head swap is alot longer away and it sucks just as i thought it would.
Anyway one cyclinder/piston has a nice small circle spot on the topish right part that is shiney. Then you can feel the normal buildup of carbon or whatever around that small circle.
Prob about 2-3 mils of buildup around it.
Not sure how/why it would be so clean on that one spot....also that one cyclinder is a much more brownish color almost all over compared to the others. I did try cleaning it off and the brown tarnish so to speak comes off fairly easy but it is alot more buildup i guess on this one compared to the others.
Any ideas? All spark plugs look normal and it's not the normal number 7 running lean.
Old Oct 6, 2007 | 08:10 PM
nightrunner's Avatar
Mr. Obvious
does it look like its where one of the valves were coming down and ever so slightly tapping it? just throwing out ideas
Old Oct 6, 2007 | 08:13 PM
KY_BOB's Avatar
That's my first thought too. What cam are you running?
Old Oct 6, 2007 | 08:15 PM
Mr. Obvious
thats all i can think of is something valve related.
TR224, IIRC
Old Oct 6, 2007 | 08:29 PM
I'm running a TR220/112LSA the valve looks perfect and in no way has any differances compared to the others.
I'll try to get a couple pics of it if the camera has enough battery power.
Old Oct 6, 2007 | 09:00 PM
Took some pics. The intake valve looks to have a little less buildup around the edges on it....compared to the others. Not sure really. Ideas.
Close up of valves.
Old Oct 6, 2007 | 09:03 PM
And the pupsta!!!!
Old Oct 6, 2007 | 09:16 PM
Mr. Obvious
im assuming no damage to the piston or valve at all ?
did you ever run any seafoam, fuel treatment, octane boost, or any other chemical through it ?
Old Oct 6, 2007 | 09:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
That is what I am thinking. There is nothing that looks too outta the norm, how many miles on the motor? I would suggest cleaning the pistons ala grippy style and puttin that sucker back together. BTW, cool pup!
Old Oct 6, 2007 | 09:33 PM
blown3qtr's Avatar
What is Grippy's style?
