Head Swap Sucks!!!! Plus Question.
Ok well so far the head swap is alot longer away and it sucks just as i thought it would.
Anyway one cyclinder/piston has a nice small circle spot on the topish right part that is shiney. Then you can feel the normal buildup of carbon or whatever around that small circle.
Prob about 2-3 mils of buildup around it.
Not sure how/why it would be so clean on that one spot....also that one cyclinder is a much more brownish color almost all over compared to the others. I did try cleaning it off and the brown tarnish so to speak comes off fairly easy but it is alot more buildup i guess on this one compared to the others.
Any ideas? All spark plugs look normal and it's not the normal number 7 running lean.
I'm running a TR220/112LSA the valve looks perfect and in no way has any differances compared to the others.
I'll try to get a couple pics of it if the camera has enough battery power.
