Head swap issues Need some input
Old Dec 29, 2012 | 08:34 AM
banjoman's Avatar
Default Head swap issues Need some input
I had to replace my cracked 706 heads.(2005 silverado with 5.3) I found a set of reconditioned 243's and had .025 milled off of them. while I was in there I swapped out the cam for a comp 212/218. Got it all back together and got a BlackBear data logged tune. Truck runs awesome. But I get a pretty good puff of Grey/Blue smoke at start up and oil consumption of 1 1/2 quarts in a 1000 miles. The puff of smoke is random. Any Ideas what went wrong? No oil consumption before the swap. I went to change the pcv valve but it doesn't have one???
Old Dec 29, 2012 | 09:03 AM
99 2500's Avatar
Could be a bad valve guide seal or a worn valve guide.
Old Dec 29, 2012 | 12:15 PM
1FastBrick's Avatar
Custm2500's Rude Friend
X2 Not all shops do good work when reconditioning.
Old Dec 29, 2012 | 12:26 PM
2000chevysilverado's Avatar
Pull the plugs the dirtiest one will be where you oil is being used at
Old Dec 29, 2012 | 07:46 PM
02 BLK WS6's Avatar
10 Second Club
^ this
When you find the culprit, pull the valve springs and check the seals.
V-seriesTech
Jul 28, 2015 12:31 PM
bsn1989
Jul 16, 2015 08:20 AM
4B11T
Jul 13, 2015 03:48 PM
MileHighSierra
Jul 12, 2015 12:23 AM
Aboss
Jul 9, 2015 10:28 AM
