Head Question - 6.0
Old Jul 10, 2007 | 01:07 AM
gcw2000's Avatar
Default Head Question - 6.0
Ok guys, I'm new here but need some help. I am building a 6.0 from a 2003 truck. I am looking to get a compression ration of about 10.5:1 and need to know how much to deck the heads to get to this point and use stock head gaskets. I also need to know how much lift I can get from a cam without having piston to valve clearance issues before or after milling the heads. I am already changing the valve springs to make sure that they can handle the bigger cam. Any help will be greatly appreciated.
Old Jul 10, 2007 | 03:29 PM
Richard@WCCH's Avatar
FormerVendor
Do you know if your 6.0l engine is an LQ4 or LQ9? It makes a big difference in calculating how much to mill to raise compression.
Richard
Old Jul 10, 2007 | 04:57 PM
gcw2000's Avatar
i believe it is the LQ4 engine. It is out of a 2003 Silverado 2500HD
Old Jul 10, 2007 | 06:00 PM
FormerVendor
If you mill off .030" from the heads, your c/r will go up to approx. 10.2:1. That should allow you to run a decent sized cam without hitting the pistons. Keep the duration under 228º@.050" and under .600" lift and your going to be alright.
Good luck,
Richard
Old Jul 10, 2007 | 06:30 PM
gcw2000's Avatar
thanks so much for the info and the quick answer.
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
USMCvet0311
Aug 1, 2015 07:45 AM
steves86ta
Jul 28, 2015 10:21 AM
bbowerman
Jul 26, 2015 10:57 PM
