Head milling theory question
I know that milling a set of heads will raise CR, so this is kind of a "check my math" type question to make sure I'm understanding how the valvetrain works.
After a head is milled, and the stock length pushrods are used, would there be an increase in lift at the valve?
Theoretically, if the lifter was unable to absorb this extra length in preload as stated above, then yes, you could get more lift. The MAJOR downfall is that the valve might not close all the way causing it to burn up and fail very fast.
I haven't given any thought to the lifter's purpose, which is why I'm glad I asked this question.
I don't understand the lifter's purpose in the valvetrain...in my mind, the cam lobes tap the pushrod, which lifts the rocker, which pushes the valve(s) open.
I have alot to learn apparently, any information is greatly appreciated.
GrooveCityZ71
Aug 31, 2015 12:05 PM
BennyB
Aug 1, 2015 08:48 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
