Head milling theory question
Old Aug 11, 2010 | 10:54 AM
RSTinOKC's Avatar
Default Head milling theory question
I know that milling a set of heads will raise CR, so this is kind of a "check my math" type question to make sure I'm understanding how the valvetrain works.
After a head is milled, and the stock length pushrods are used, would there be an increase in lift at the valve?
Old Aug 11, 2010 | 12:48 PM
JS01's Avatar
No, you'd have more lifter preload though. Or if you milled it a whole lot you might bottom out the lifters and start hanging the valves open when the cam is on the base circle...
Old Aug 11, 2010 | 12:51 PM
Coban's Avatar
Theoretically, if the lifter was unable to absorb this extra length in preload as stated above, then yes, you could get more lift. The MAJOR downfall is that the valve might not close all the way causing it to burn up and fail very fast.
Old Aug 12, 2010 | 11:37 PM
RSTinOKC's Avatar
I haven't given any thought to the lifter's purpose, which is why I'm glad I asked this question.
I don't understand the lifter's purpose in the valvetrain...in my mind, the cam lobes tap the pushrod, which lifts the rocker, which pushes the valve(s) open.
I have alot to learn apparently, any information is greatly appreciated.
Old Aug 12, 2010 | 11:45 PM
smokeshow's Avatar
Mod with training wheels
Cam lobes don't tap the pushrod...there's a lifter in between
GrooveCityZ71
Aug 31, 2015 12:05 PM
BennyB
Aug 1, 2015 08:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
