head help
Old Nov 21, 2006 | 02:25 PM
GMGen3's Avatar
Default head help
Hey guys, I'm new here but I have visited many times & enjoyed the advice Anyhow, a mild street daily driver motor could be in the future works (like heads & cam) and I was wondering what stock heads might be an improvement. The motor is a stock 5.3 (not picked out a cam yet)....could I benefit from LS1 or LS6 heads? What about stock 6.0 heads?
Thanks
Old Nov 21, 2006 | 03:18 PM
yurs78's Avatar
Welcome! It all depends on what your goals are with the engine for HP/TQ. Once you decide how crazy you want to get with it, the parts are easier to pick from that point on. Good luck!
Old Nov 21, 2006 | 03:27 PM
onebadrubi's Avatar
ls1 heads flow just as good as you stock 5.3l heads but will just bump the compression.
ls6 and stock 6.0l heads(317's) flow the same but the ls6 will raise your compression ratio and the 317's will lower your compression ALOT.
Out of those 3 heads and money allowing a set of 243's would be nice. Then need alot more info to help with the cam part.
Old Nov 21, 2006 | 04:19 PM
GMGen3's Avatar
yeah it definately sounds like the ls6 heads are the way to go, but I am a little coufused about the ls1's. I thought f-body guys were after the 5.3 heads to raise compression, so wouldn't ls1 heads lower compression on a 5.3?
Old Nov 21, 2006 | 04:30 PM
That was before the LS6 heads became available.A lot of builders were porting 5.3 heads and installing 2.0" intake valves,when the better heads bacame available most builers quit using the 5.3 heads.
Old Nov 21, 2006 | 05:06 PM
GMGen3's Avatar
but would the ls1 heads hurt or help the 5.3
Old Nov 21, 2006 | 05:17 PM
If you are planning to keep the 5.3 the LS1 head's 2.0"intake valves will be partially shrouded by the smaller bore,the ports don't flow any better than the 5.3 heads and the compression would be reduced by it's larger chambers.
Old Nov 21, 2006 | 05:48 PM
GMGen3's Avatar
Thanks whitt1, sounds like the only way to go is the ls6's.
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
