Head gaskets
Old Dec 15, 2010 | 01:20 AM
TA63's Avatar
Default Head gaskets
What is the preferred head gasket for a moderate 6.0 build? I am adding 243 heads, long tubes, and an EPS cam to a stock 6.0 lower end. What gasket and how much should I cut my heads to achieve 10.5 to 1 compression?
Old Dec 15, 2010 | 01:27 AM
Mangled03gmc's Avatar
Baltimore Whore
I prefer OEM MLS gaskets, but to get that kinda comp, you might need to run a thinner then stock gasket depending on if its a lq4 or lq9.. Check into commetic
Old Dec 15, 2010 | 01:44 AM
TA63's Avatar
Its an LQ4, but the 243 heads have 65cc chambers. I think if I cut .020 off down to 62cc I would be close, but wanted to ask.
Old Dec 15, 2010 | 05:10 PM
budhayes3's Avatar
PT's Slowest Truck
I like the GM MLS gaskets myself...
Old Dec 15, 2010 | 05:23 PM
1slowz71's Avatar
at 62cc it put you in cr of 10.501:1 with the stock head gaskets , i always run the stock genium gm head gasket but , it up to you ,good luck
Old Dec 15, 2010 | 05:48 PM
TA63's Avatar
Good to know, thanks. Should be about right for pump gas I think.
Old Dec 15, 2010 | 05:52 PM
1slowz71's Avatar
just fine iam running 61cc at the moment and it great , but after this weekend iam going to run on 59cc should run a little better! on an lq4
lsxperformance
Apr 20, 2016 12:17 AM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
