which head gasket for 5.3?
Old Apr 9, 2013 | 02:05 PM
dirty_old_chevy's Avatar
Is the combustion chamber diameter on the 243 heads larger than the cylinder bore of a 5.3? If so, I would definately get 5.7 gaskets, so you dont run the risk of the head gasket hanging out into your combustion chamber. Or just get L33 gaskets, since they came with 243/799s from factory.
Old Apr 9, 2013 | 02:36 PM
devink's Avatar
No they are 5.3 heads (862 castings)
Old Apr 9, 2013 | 02:55 PM
oops, I dont know what made me think that, lol. I would run 5.3 gaskets, but if they had combustion chamber work to unshroud the valves, it still wouldnt hurt to measure the combustion chamber diameter.
Old Apr 9, 2013 | 03:58 PM
devink's Avatar
Thanks for the tip. They did clean up the chambers and the valves are 2.02/1.6 so it would be a good idea to measure.
Old Apr 9, 2013 | 04:05 PM
GMCtrk's Avatar
I'd use ls9 head gaskets. $90.
Old Apr 9, 2013 | 04:31 PM
grey matter 04's Avatar
13 Second Truck Club
Doubt he does that!
He's unsure of using ls1/6 gaskets with a bore size of 3.910 vs a ls9 gasket bore of 4.100
Old Apr 9, 2013 | 04:33 PM
devink's Avatar
So it doesn't matter if the ls9 has a larger bore? This is what I'm confused about.
Old Apr 9, 2013 | 05:50 PM
craigsix's Avatar
small block chevy 350 gaskets arent 4.00 bore they are larger and people have been using them without problems.
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
bbowerman
Jul 26, 2015 10:57 PM
