head choice and opinions needed.
Old Dec 5, 2009 | 04:20 AM
vff_jeff's Avatar
Default head choice and opinions needed.
I have a Lq4/th400 stalled that I originally set up for boost.
it has ARP studs, rod bolts ect. Medium cam, turbo gapped rings, UD pulley ect.
Right now I have ported, polished 317 heads with chamber work, and milled .010.
I cant go turbo for a while, And I have a set of 706 truck heads also. But they are stock. Which ones should I run for best performance? I will be running stock manifolds, and have it SD tuned. 3.42 gears on a 30'' tire. In a 4k# truck.
I know My ported heads flow way way better, but would the small combustion chamber yield better performance?
Old Dec 5, 2009 | 11:10 AM
terravast4's Avatar
the 706's have pretty good flow I think the increaced compression could get you some more power.
Old Dec 5, 2009 | 11:31 AM
Do you have someone that does all of your head work? If so you could just have them put bigger valves in them.
Old Dec 5, 2009 | 11:34 AM
LsxCody's Avatar
what happened to the turbo setup? i would just get the 706s ported
Old Dec 5, 2009 | 11:41 AM
Mangled03gmc's Avatar
Baltimore Whore
I put the 317's on it...
Old Dec 5, 2009 | 11:46 AM
Would the flow of the smaller intake valve openings have any affect in HP or Torque?
Old Dec 5, 2009 | 04:57 PM
vff_jeff's Avatar
I did, but If I put the 706 heads on, Im just going to slap them on.
Ran out of money. And need the motor in, as the v6/tranny is going out. I thought about it, but when I do get money for turbo, Ill put the 317's on (If I choose to run the 706)
You think? The 317's are already on and torqued down. But If the 706 will make better power ect... I will run them. You think the good flow and Lower compression will make more power than High compression and lower flow?
I dont have a clue.
Keep the 2 cents coming guys.
Old Dec 5, 2009 | 05:14 PM
LsxCody's Avatar
i would just keep the 317s on, it will save u time when u do go turbo....sucks about the money situation...i know how u feel
kush killer
Feb 17, 2016 09:20 PM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
