GTP stage 2 heads on a 5.3l
Old Aug 30, 2006 | 07:19 PM
Redshadow's Avatar
Default GTP stage 2 heads on a 5.3l
Got a chance at a great deal on a set of GTP stage 2 heads and a TR224 cam as a package deal, and wondering if these will work correctly on a 5.3L. Guy with the heads said they were truck heads, anyone know if this is true? I'm assumining they use the truck heads to raise the compression on the F-body's. Concered about loosing compression or flow issues with the larger valves. Thanks!
Old Aug 30, 2006 | 08:25 PM
Pass on the heads your smaller bore won't let them flow to their full potential and a TR224 is a lot of cam to drive on the street.Go with your stock heads,a Comp 216/220XER and spend the difference on a good set of long tube headers.You'll make good power and that cam has plenty of lope to impress your friends.
Old Aug 30, 2006 | 09:29 PM
Redshadow's Avatar
Well, the 4.10s go in next week, the 3,000 converter the week after, the long tubes somewhere during the next month. So I actually think the cam will work on my combination. I'm just wondering if the heads will cause issues with shrouding. Hoping to get the truck into the 12's-low 13's. Setting aside money now for when the tranny lets go.
Old Aug 30, 2006 | 11:16 PM
02sierraz71_5.3's Avatar
there are guys that run those numbers NA RCSB with a cam only. Im with Whitt1. Those heads are made for larger bores like the ls1 and alot bigger cams. If I were in your shoes I would take the stock heads mill them .040, valve job, springs, maybe seals while your in there. I like the 224 on a 112 or lower lsa/Icl. dual 2.5" exhaust with an xpipe
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
KyleW707
Jul 29, 2015 08:17 AM
lxcoupe
Jul 27, 2015 08:19 PM
