Cracked rod
when i was looking thru arp rod bolts i seen the "cracked rod" i didnt really understand why they called it that and i pulled one of my pistons out and i was like WTF..the rod and rod cap were one piece and they broke it from what it looked like to make the cap..weird
sorry there's no significance to this thread
No actually it is one of the best designs ever. many manufacturers have realized the benefits of this...
imagine taking aq standard small block connecting rod, and cap (with a flat surface) when you mount it, that flat surface can slide (especially with extreme pressure/ horsepower levels)
now take a rod that you make with a perfectly round bearing surface, and you brak it.... it will have a very distinct ridge, so it will only go together one way, which also means once assembled the surfaces will not slide, and move out of place.
dodge did it with the srt-4 engine also, and amg mercedes are doing it. porsche has done it for years. it is actually a genius design. I just wish aftermarket would make a strong set that were split.
Why would they need to when they use MUCH better metals and forged them. My rods are a hell of alot stronger than any powdered metal cracked rods.
peace
Hog
and a hell of alot more expensive......
lukn4trbl355
Oct 21, 2015 11:19 PM
