View Poll Results: For you who havent had your daily "Which Cam?" question
GT2-3
45.45%
Ultra TQ
0%
Trucker
27.27%
Other
27.27%
Voters: 11. You may not vote on this poll
GT2-3/Trucker/Ultra TQ/Other Cam poll
Old Oct 25, 2005 | 12:19 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Default GT2-3/Trucker/Ultra TQ/Other Cam poll
Swapping the 5.3 for a 6.0.
Radix on top, trying for 8-9#'s boost. Might see a 50 wet shot some day
4:10 gears/Eaton
5800 lbs with me in it
Recommend the Best cam for low end grunt+smooth to mild lope+power to 6K rpm
GT2-3:
207/220, .581/.581 118.5 lsa (I think)
Ultra TQ
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551/.551 OVERLAP 48* LSA 116*
The Trucker
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
* LIFT .551/.551 OVERLAP 53* LSA 115*
Will I NEED hardened pushrods/Springs/Rockers with the one you suggest?
I don't mind a little lope but want good driveabilty
Thanks.
Old Oct 25, 2005 | 09:21 PM
1SlowHoe's Avatar
nobody has any of these cams?
Old Oct 25, 2005 | 09:26 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Blownchevy has the Lingenfelter cam pm him he said it was deisgned with the magnacharger in mind.
I will tell you this myself and mjhoward put a comp 216/224 .558 .558 114 in his truck and damn that thing pulled good and it has a little lope to it also.
Old Oct 25, 2005 | 09:38 PM
BlownChevy's Avatar
blownerator
25 Year Member
I voted
I will admit that I do not speak cam very well, however I do know what works well for me! LPE GT2-3
Old Oct 25, 2005 | 10:14 PM
1SlowHoe's Avatar
This is where I get confused. The Trucker and the GT2-3 both say they were created for the Radix specifically. But the numbers are so different. Can anyone tell me what the different numbers will mean in the area of:
Low end TQ
Lope
Drivability
Pull up to what rpm?
I have to order this sucker by Friday to get it in time.
Old Oct 26, 2005 | 08:32 AM
2nd Sierra's Avatar
to the top because I'm in the market for a cam as well
leaning towards the gt2-3 simply because of a lot of good experiences with it here and over at silveradoss.com
Old Oct 26, 2005 | 08:57 AM
Mr. Sandog's Avatar
Wow, surprised you don't have more votes than this. I'd be tempted to go over to LS1Tech and post the same question in the LS1-LS6 Internal Engine section, I bet you get many more responses than this. If you do, be sure to remind them you have a truck and give them all the relevant info like weight, gears, tire diameter, etc.
Anyway, I voted for the Trucker, simply because this is going into a 6.0L. I think you can get away with it. If you were sticking with the 5.3L, then I'd say the GT2-3 for sure. But the extra cubes do make a difference. What seems big in a 5.3L can seem 'just right' in a 6.0L. Plus that cam looked lonely with no votes.
Question - will you have an aftermarket TC with either of your new trannies? Reason being, if you don't, there is the slightest chance you will lose a teensy-weensy low end with the Trucker (but maybe not, since you will have the Radix with what, a 2.5" pulley? ).
However, if you even have something like a 2600 stall, you will have zero worries. Too bad guys with 220-224 size cams aren't weighing in here.
Old Oct 26, 2005 | 10:25 AM
1SlowHoe's Avatar
I have a tiny bit bigger stall now. 2000 I think. I wont do a stall right now, but when the tranny need replaced I was thinking 2400-2600. I already get 12mpg so I dont want to go any bigger. I heard a sound clip of the Trucker in a 5.3 and it sounds mean. I like it. The wife will hate it. EVEN BETTER!!
Old Oct 26, 2005 | 10:35 AM
moregrip's Avatar
what a rush!
only thing I can offer is the LPE GT2-3 idles stock in a 5.3, I couldn't tell anything was there at all so that might not be the one for you.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
