got me a rebuilt ls1 for my truck!!!
Old Apr 23, 2010 | 10:07 PM
  #31
little update....as all of u know about the BS i have gone through with the iron ls1 I bought, i said screw it and jumped back on the aluminum ls1 i had. i had bought it back in march, it needed new cam bearings b/c they were not installed correctly, and one was too far back blocking the oil passage. at the time i didn't know the whole rotating assembly had to come out to do that. Anyhow, tore it down, had new Durabond cam bearings installed. I then went to Polydyn, there are here locally in Houston, and bought a set of clevite77 H series main and rod bearings with the Polydyn coating on them. Installed the crank, had a buddy( montecarloss) install the rods and pistons and arp rod bolts for me. And tonite i just ordered a set of arp head bolts, head gaskets, melling 10295 oil pump, and my Cam. Im going with the TSP torquer v2---232/234 595/598 112. should run good. Im putting my 706s on it for now, that should be right around 10.9 cr with those heads. im shooting for memorial wknd to do the swap!!
Old Apr 24, 2010 | 12:13 AM
  #32
brent5631's Avatar
Nice to see your moving on i guess. Will rebuilding it affect when you take him to court at all?
Should be a nice setup when done.
Old Apr 24, 2010 | 02:20 PM
  #33
im building my aluminum ls1, not the iron one i got screwed on.
Old Apr 25, 2010 | 05:16 PM
  #34
dug's Avatar
dug
Banned
good luck. dont give up on getting your money back. Find out all his info and call his local detectives
Old Apr 25, 2010 | 05:46 PM
  #35
sent him a cert. letter 2 wednesdays ago, a "demand for payment" letter, he had 10 days to respond, which of course he didnt. goin to the court house tomorrow and finish filing. had to send the letter b4 i could do the final paperwork.
Old Apr 26, 2010 | 03:00 AM
  #36
Spoolin's Avatar
GFYS and STFU
Very glad your going through with this!!
Old Apr 29, 2010 | 04:15 PM
  #37
well, been spending some money on my new motor. My order came in with my cam, ARP head bolts, melling oil pump, and head gaskets. Went to dealership today and picked up new lifter trays and cam retainer plate. Bought a new set of ls7 lifters and new ls2 HD timing chain from a buddy,and I am borrowing a pr length checker from a buddy to check pr length so i get the preload correct on my lifters. gonna stick with my 706s for now. It will put my CR at about 10.9.
Old May 2, 2010 | 10:39 PM
  #38
got the motor together this weekend. bought a set of ported 706s for it. cleaned up oil pan i bought and installed it. Here is whats in the motor:
Rebuilt ls1 shortblock
ARP rod bolts
Polydyn coated Clevite 77 h series rod and main bearings
Melling 10295 oil pump
TSP Torquer V2-232/234 595/598 112lsa
New LS2 HD timing chain
New LS7 lifters and trays
GM MLS head gaskets
ARP head bolts
P&P 706 heads
New front and rear seals
here are some pics
http://i974.photobucket.com/albums/a...yd2000/ls1.jpg
http://i974.photobucket.com/albums/a...2000/ls1-2.jpg
http://i974.photobucket.com/albums/a...2000/ls1-3.jpg
Old May 2, 2010 | 10:53 PM
  #39
Wheatley's Avatar
Truck Sponsor
ARP rod bolts
GM MLS head gaskets
ARP head bolts
P&P 706 heads
here are some pics
Finally.
It was a shitty deal but you went through with it!!
Old May 2, 2010 | 10:58 PM
  #40
definitly buddy!! that pr checker helped out bro, thanks again Charlie. Memorial weekend cant come quick enough!
