Got a little cam for the 5.3
Old Jul 23, 2005 | 03:09 PM
  #31
02sierraz71_5.3's Avatar
Originally Posted by Flyer
The ehads will be stock 5.3's for a while. Depending on how it holds and the money situation, there's may be a set of 205's sitting on top, but once they come, they will prolly come with a 6.0.
your gonna leave alot on the table having stock heads. Even with my cam I would have gained more after 6200 with porting the heads, have you thought about porting them yourself
Old Jul 23, 2005 | 09:27 PM
  #32
Flyer's Avatar
I would be loosing a lot if the motor came loose and killed a set of 205's. Keep in mind this thing's gonna spin up to around 7200 or so. If need be, I have an ls1 intake laying around I can use. I just gotta get some fat injectors for it.
Everyone is screaming for someone to stick a monster cam in a 5.3. It's fixing to happen.
Someone you mentioned, I'm not saying who in public, I wouldn't put any stock in what he has to say. If you want details, PM me.
Old Jul 23, 2005 | 09:39 PM
  #33
I was just thinking about doing a cheap homemade port job on the heads, with that ls1 intake should take care of alot of it. Im shore you now everyone says the ls1 intake flows alot better past 6k
Old Jul 24, 2005 | 06:11 PM
  #34
Save up your pennies and go with a 402 ci LS2 with 225 AFR heads and a carb setup.Then that cam will be pretty doscile.Maybe 650 NA horsepower then add a 200 shot to put it in the 10s.
Old Jul 24, 2005 | 09:52 PM
  #35
Originally Posted by litreddevil
i don't know why you'll say that the intake don't flow i have seen 7400 and only because of valve float i didn't do it every pass. now i have my 6.0 and solid lifters i will be spinning it up again to 7000 7200 rpm.
if you put a ls1 intake with that big cam in a truck you really going to need a 5k converter cause you will lose even more low end.
just my 2 cents i think with that cam you will need @ least 4.56 gears or 4.88 and a 3k or 35k stall. i will love to see the out come.
IMO---FLYER'S CAM STOCK HEADS PTC 3500 4.56 GEARS SHIFTING @ 7K.I COULD CARELESS ABOUT DYNO #,I WANT TO SEE IT GO DOWN THE TRACK.THIS COULD BE VERY INTERESTING.
its been well documented the truck intakes arent designed with an rpm range above 6000+ thats why alot of guys use an ls1 or fast and pickup 20+rw up top. Does it flow good of course can it flow better yes.
Old Jul 30, 2005 | 06:43 AM
  #36
Sport Side's Avatar
I'll be bolting on an LS6 intake pretty soon to put all of these theories to rest.
Old Jul 30, 2005 | 07:14 AM
  #37
one03sierra's Avatar
Formerly one92rs
Talking
these theories you are speaking of have been tested thouroughly. there are sevral people on here that have done the swap. the low end is the same. they gain some hp up top. but you are driving a truck. a truck doesnt weigh 3700 pounds and shaped like a rocket. you need torque to get these pigs rolling. the camaro guys even like the truck intake for the low end torque. and there have been several flow test to prove the truck intake works. imo. you may gain some hp up top above 6000 rpm's. but i believe that the 300 or 400 rpm's above 6000 is a small gain for the truck intakes gain from 700rpm's up to 6000. good luck.
Old Jul 30, 2005 | 07:55 AM
  #38
Sport Side's Avatar
From your description, it doesn't sound like these tests have been done "thoroughly". You mentioned, low end is the same but later on describe how a heavy vehicle needs torque to accelerate. Well, if the gains are the same for low end but, there is a bump in upper rpm power... What is there to loose?
Can you give me a link to some of these results? I'm not interested in the magazine articles, I have seem them. I know Blacksheep saw very decent gains with the LS6 swap.
Up above in this thread, Reddevil and 02sierra are mentioning how the LS1 intake shows an improvement in "high rpm" power. The LS6 intake has been tested thoroughly showing gains across the entire powerband against the LS1.
What I'm getting at is it sounds like there is a huge amount of heresay going on. Things are not adding up so it's definetly worth a shot.
Old Aug 1, 2005 | 11:02 AM
  #39
Flyer's Avatar
I got the cam in ... and from the setometer, it's still pulling hard as hell at 7000. I didn't think it would fall off at 6200 like predicted. I'll try and get the G-Tech on it to show the G's. It will also show a HP/Torque curve, but the actual numbers won't be accurate.
Old Aug 1, 2005 | 01:15 PM
  #40
Sport Side's Avatar
Flyer, horsepower "should" peak at or around 6200-6400 rpm.
I never stated power would fall off but, what will happen is that the hp curve will flatten out tremendously.
Why?
Because the intake manifold has become a significant restriction at this point. As stated previously, this camshaft is large enough to peak at 7,000+ rpms given the proper induction.
Here are some examples of these 62/64 hundred rpm peaks I keep mentioning.
G5X2
http://members.***.net/moconnor4ss/Haldynox2.jpg
G5X4
http://members.***.net/moconnor4ss/Ryandyno.jpg
