Goal 600hp.....Which First.....Whipple or Cam
Old Jun 22, 2020 | 09:33 PM
ZO6Ted's Avatar
Disadvantage in labor maybe. Shouldn't be a huge deal but the Whipple will be WAY more fun until! Torque is incredibly more than a cam. I'm still pissed about not doing my research of having to do injectors and hp pump b4 installing Whipple. I still haven't pulled it off to do that. Injectors could have let me do E85 easily with no other changes and another 50 hp at least.
Old Jun 22, 2020 | 09:45 PM
68Formula's Avatar
If you do the Whipple first, will you have enough fuel without the +32% fuel lobe? I would think the cam first would be prudent to help insure enough fuel when the blower goes on.
Old Jun 22, 2020 | 09:51 PM
allenk4's Avatar
ZO6Ted,
I am leaning toward doing the Whipple first....much easier install...bigger HP increase.
The fuel system in the L86 should easily support the Whipple on 91 octane.
Some say, with a +32% fuel lobe cam, the stock fuel system could support e85....others disagree. I wonder if the addition of water/methanol injection would allow for e85 without upgrading the stock fuel system, which shows 123 lbs./hr. (2,205 max psi). I123 lbs/hr x 1.32 = 162 lbs/hr. with the +32% lobe
Hopefully, someone will chime in regarding the duty cycle of the 12656931 injectors. I have seen calculators for selecting injectors, but they all seem to be for port injection as the duty cycles you can select from only go down to 75% or so.
Old Jun 23, 2020 | 06:30 AM
smokinlmm's Avatar
Originally Posted by arthursc2
the 14 bolt G80s are weak? I think hes gonna be fine. He has the 9.5" AAM SF out back and those G80s are pretty stout
Take a look at what happended to mine in my rcsb thread. They aren't designed to handle 600+rwhp power slides and burn outs. Lol...
Old Jun 23, 2020 | 07:13 AM
arthursc2's Avatar
Seriously doubt he's gonna be sliding the SUV, for one thing
I dont know the AAM line up, but your RCSB would have had a 12 bolt at best, from the factory. Dont know what axle you had in it, if you broke a 14b G80, heres a cookie
Ppl have broken gen4 rods as well, I guess those are now crap too? How about all them 4L80s that lost reverse? garbage?
Old Jun 23, 2020 | 06:13 PM
smokinlmm's Avatar
I broke an 8.6. I didn't know that the escalade had a 14 bolt AAM in it. My bad
Old Jun 23, 2020 | 08:42 PM
ZO6Ted's Avatar
Originally Posted by allenk4
ZO6Ted,
I would do injectors and Whipple first as LT4 injectors are not that expensive. It will support low 600's I'm pretty positive without going back again and checking. Cam will only enhance and allow E85 then do a LT4 hp pump while apart. Check out what Armageddon Turbo did on an L86. Upper 600's on stock fuel as I recall but PLEASE verify. Had to turn it down for longevity of stock ring gap and pistons. Do the Whipple I've never been sorry for a DD. Just should've done injectors as well.
Old Jun 26, 2020 | 01:59 AM
allenk4's Avatar
LT4 Fuel Pump with a Whipple sounds like it requires significant modification of the Whipple to make it fit.
Will upgrading to LTt4 injectors allow e85 ?
Old Jun 26, 2020 | 01:37 PM
ZO6Ted's Avatar
There is a you tube vid by Pmoore showing how to clearance it. You just need a grinder and follow his guideline on exactly where and how much. Doesn't look all that involved. Yes on the injectors and E85.
JADSCOOP
Sep 10, 2019 09:03 AM
ou812sm
Jan 1, 2013 08:22 PM
ou812sm
Jul 29, 2012 03:50 PM
camarossls12001
May 18, 2008 09:23 PM
gao8302
Aug 15, 2006 09:56 PM
