cam for a whipple
Old Jul 25, 2012 | 08:23 PM
ou812sm's Avatar
Default cam for a whipple
I'm thinking about putting a cam in when I put my whipple on what kind of cam should I look for my truck is an 09 denali awd with 3.08 rear end for gears
Old Jul 28, 2012 | 06:05 PM
ou812sm's Avatar
Well no one can give me some direction
Old Jul 29, 2012 | 07:30 AM
LS1TRUCKGUY's Avatar
little more info on the drivetrain? what heads are on it?
Old Jul 29, 2012 | 09:44 AM
ou812sm's Avatar
The 6.2 is stock tq is stock rear end is 3.08 with 6l80 for tranny if I due a cam swap i will get arh 1 7/8 for the headers
Old Jul 29, 2012 | 09:56 AM
03sierraslt's Avatar
Do you plan to keep the converter stock?
Old Jul 29, 2012 | 11:43 AM
ou812sm's Avatar
No i plan on stock converter until I have to do something to the tranny
Old Jul 29, 2012 | 11:53 AM
Boober's Avatar
The problem is that your sample size is pretty small. There aren't that many 6.2L nnbs guys running cams and most appear to be doing the VVT delete option. Even fewer are running superchargers and of those, there are 2 of us (at my latest count,
Bdubb has removed his) who are running Whipple. I personally have no intention of changing cams. Once my latest work is done, I'm going to be at the ragged edge of safe/reliable power for a stock long block 6.2 (imo) and I'm going to concentrate on fine tuning my tune and improving my driving at the track. With only a Whipple kit (at 9psi) and a good (non-Whipple sourced) tune, you will already be close to 500whp.
Old Jul 29, 2012 | 01:31 PM
ou812sm's Avatar
Does anyone know if the vvt cams from comp cams any good
Old Jul 29, 2012 | 03:50 PM
zachm89's Avatar
Give Texas speed a call about the VVT cams, I think they would be able to provide you with some good info. If you're planning on doing a cam along with that whipple they should be able to point you in the right direction for a cam suited for your mods.
lawhitediamante
Aug 12, 2015 12:14 PM
MS3Z
Jul 30, 2015 06:17 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
ou812sm
Jul 18, 2015 01:12 PM
