gen1?
Old May 6, 2007 | 10:13 AM
seeyaa's Avatar
Default gen1?
my brother has a 79 305 and we want to build a 383 are the mains the same size as a 350.
Old May 6, 2007 | 12:00 PM
YenkoST's Avatar
If you use a 3.75" crank for the 350 mains then yes it will work...you can find those in a 383 kit for the 350 engine. If you use a 400 (3.750") crank then no, you will have to have some work done to it for it to work. Easiest solution is get a 383 stroker kit for a 2 pc. rear main 350 unless you get a 350 block with a 1 piece rear main.
fastestbrickonearth
Nov 18, 2012 06:59 PM
darnie
Jun 22, 2012 10:21 PM
lsvega-s
17
Feb 12, 2011 07:34 PM
AintNoHo
Apr 20, 2006 01:55 PM
