Gen IV 6.0 block with Gen III internals & electronics
Old May 9, 2023 | 10:45 AM
  #31
shakenfake's Avatar
Shlumpt
5 Year Member
Open it. You know you want to.
Old May 9, 2023 | 10:48 AM
  #32
RDF1's Avatar
DuNnO
5 Year Member
PM Sent. I can fix you up with a cam
Old May 9, 2023 | 10:57 AM
  #33
strutaeng's Avatar
5 Year Member
Thank you!
Old May 11, 2023 | 09:57 PM
  #34
strutaeng's Avatar
5 Year Member
I dug out the heads from garage attic. I was going to ask for advice on them, but I think I already know the answer 🙄
They are pretty rusty, which is obviously a problem. But one one of the heads I see 2 of them (both the exhaust ones) are hung open, so that means they are bent. Toss them in the trash bin?! 🤕
Old May 11, 2023 | 10:00 PM
  #35
1FastBrick's Avatar
Custm2500's Rude Friend
Those 2 appear to be bent.
Doesn't mean the heads are bad, Just means you have a few valves that need replacing.
Old May 12, 2023 | 10:55 AM
  #36
strutaeng's Avatar
5 Year Member
I don't know what to do now. Should I order the tools to take them apart and at least see if I can lap the ones that look okay and replace the bent ones?
I called my local machine shop and said it's about $300 to recondition them for labor, plus cost of new valve seals and actual bent valves cost. He says they machine them instead of lapping them? Not sure what that means.
I asked about rotating assembly balancing and he said they do it for $200. So I think I'm just going to take everything to them at once when I'm ready. They are only like 5 miles from me and open on Saturday morning.
Old May 12, 2023 | 11:38 AM
  #37
RDF1's Avatar
DuNnO
5 Year Member
the cost of the valves and recondition the heads will be about your best option for the money.
Old May 12, 2023 | 12:01 PM
  #38
1FastBrick's Avatar
They No longer Grind with a stone and hand lap the valves like the old days . They use a cutter to cut the valve seat angle. This is more accurate and when done correctly seals properly with out the need to lap the valves for a good seal.
The bent ones are junk. Depending on the how the others look they will reface them if they are salvageable. They will also check the fit of the valve guide to make sure they they are within spec.
Old May 20, 2023 | 09:55 PM
  #39
strutaeng's Avatar
5 Year Member
Ok, finally found the courage to file the rings. After filing a few I kinda got the hang of it.
Filed them to for a street application per the Hastings table, using 4.020" bore diameter:
0.020" for 1st compression ring
0.018" for 2nd compression ring
0.015" for oil control rings
I'm not clear on the instructions on the expander ring joint location. It says to place it above the piston boss area. Where is that on the piston? Other articles I've seen say it's the outside of the engine (3 or 9 o'clock looking down)?
Old May 20, 2023 | 10:46 PM
  #40
RDF1's Avatar
DuNnO
5 Year Member
Ive never read that far into the instructions.
But i always put the ring joints to the front or rear of the engine. dont forget to deburr the cut edges of the rings also.
