found this while changing the oil
Old Sep 7, 2008 | 06:20 PM
TG02Z71's Avatar
Almost looks like the end of a bolt that had been drilled out to remove after maybe a head snapped off?? Look at the divot in the center, like something a drill would leave if someone drilled a broken bolt out???
Many a sleepless night are in your future wondering WTF this little critter is.
Unless of course you send this thread by link to 200 of your closest friends, then you will have good luck for 7 years and fall in love inside of a week!!
Seriously, I hope it's nothing.
Old Sep 7, 2008 | 09:51 PM
budhayes3's Avatar
PT's Slowest Truck
That's what I was thinking, the concave part looks like it was drilled...
Old Sep 7, 2008 | 10:05 PM
Stoichiometric's Avatar
The diameter looks similar to a valve stem, you would know if that came apart. Could also be a drilled bolt from somewhere as stated, maybe it fell in from somewhere else at some point. Its time for self diagnosis at this point, if the truck thinks that it needs that part it wil be sure to let you know.
Old Sep 7, 2008 | 11:11 PM
Wilde Racing's Avatar
How do I change this text
Originally Posted by Stoichiometric
if the truck thinks that it needs that part it will be sure to let you know.
LMAO... yea... who needs bolts anyways?
Old Sep 7, 2008 | 11:25 PM
00ChevyScott's Avatar
Wearin' da big hat
maybe its that damn'd sasquatch again!
Old Sep 8, 2008 | 12:29 AM
7845's Avatar
Banned
i found a similar piece of metal like that before in my pan. it had turned out to be part of the front cover where the front 10mm bolts go thru. i had alittle to much Right Stuff and when i torqued the cover down the Right Stuff had cracked the cover where the bolt proceeds. nothing major of the cover still using it
Old Sep 8, 2008 | 09:05 PM
LS1TRUCKGUY's Avatar
that is awesome
Choda
Jan 22, 2026 02:03 PM
B.love18
Sep 21, 2015 08:31 PM
Noah Burns
Sep 7, 2015 05:50 PM
superchomper2003
Aug 26, 2015 09:39 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
