Forged 5.7 or Forged 6.0
Old Nov 21, 2007 | 04:07 PM
  #21
ZO6Ted's Avatar
Thanks guys, I am really excited about this! I've got a little bit to digest but time is on my side...busy with other issues right now. Keep the ideas coming though, I'm listening.
Old Nov 21, 2007 | 05:19 PM
  #22
tarinitup's Avatar
9 Second Truck Club
Check out the fastest truck list. Everone with 6's in the 1/8 or 10's in the 1/4 are running > 347 cubed motors with the exeption of two lightnings. I don't think it will be as easy to reach 6's on a 347 cause no one on the fastest truck list has.
Old Nov 22, 2007 | 09:25 PM
  #23
99Silverado5.3's Avatar
No replacement, for displacement.
Old Nov 24, 2007 | 08:39 AM
  #24
TG02Z71's Avatar
Another question I think is relevant for this thread would be heads.
Will stock 5.3l heads develope too much compression when used in a bored to a 5.7l set up?
Are there pistons out that will drop the compression to a safe 9-9.5-1 ratio?
I'm trying to use off the shelf components not expensive specials that will blow the budget.
I have heard about swtitching to 317s but don't know much about the cc capacity of all the LS series heads that would be compatable in a build like this.
Is there a thread somewhere with specs for alll the LS1, LS2, LM7, heads etc??
Old Nov 24, 2007 | 09:17 AM
  #25
ZO6Ted's Avatar
From what I understand, the hot ticket is 317's because they flow the same as LS6 heads and they are 72's allowing more boost.
Old Nov 24, 2007 | 09:58 AM
  #26
TG02Z71's Avatar
Looks like I'm going to have to put together the final list with the help of someone like WCCH so I know the compatibility of all the components in the mix.
I wonder if the truck manifold fits all LS heads except for the L92 of course.
Old Nov 24, 2007 | 10:26 AM
  #27
When the 5.3 block is bored, there are several different off the shelf pistons available for it, even with a dish big enough to run the 5.3 heads. I would personally pick a piston that I could use with the 317's to end up with the desired compression.
Even on a stock 5.3, you could just swap to the 317s and drop the compression as well as pick up flow.
Old Nov 24, 2007 | 10:27 AM
  #28
yes, the truck manifold fits all the heads except the L92s
Old Nov 25, 2007 | 07:23 PM
  #29
ZO6Ted's Avatar
How big of a motor will the stock manifolds support? What about the stock exhaust with cats? Don't really want headers or cat delete.
Old Nov 25, 2007 | 07:41 PM
  #30
BlownChevy's Avatar
blownerator
25 Year Member
I think the stock manifolds are good to about 450RWHP, then they become a cork.
