forged 370 with small bore heads
Old Mar 23, 2015 | 09:44 PM
lukn4trbl355's Avatar
Default forged 370 with small bore heads
Had a quick question for some of you gurus out there. I've been debating building a forged piston/rod 370 and finding some shavings im a little closer to pulling the trigger. My only dilemma is that I dropped a big chunk of change on some small bore tfs 205 comp. ported heads. I know the chamber size won't be helping anything as well as the intake runners being too small for the goals I have in mind. I mean for a temporary deal how do you think they'd do just until I can afford a set of tea/tfs 245s? Or am I better off just sending these heads out to tea for porting opening up the chambers etc I'm thinking a high compression 11.5-12:1 370 240s duration cam and possibly spraying it later on down the road.
Thanks in advance
T.J.
Old Mar 23, 2015 | 11:32 PM
gamble686's Avatar
Sell the tfs205 heads and buy some 243/799 heads and save for better ones.
Old Mar 24, 2015 | 06:24 AM
dirt track racer 81's Avatar
Sell those and run stock l92 heads for the time being.
Old Mar 24, 2015 | 04:20 PM
Only downside is I just scored a fast 102 but that might have to go up for sale. I spun the filter at work and things aren't looking too promising
Old Mar 24, 2015 | 08:17 PM
Well the trigger has been pulled on a 370, I'll probably call tea tomorrow just for a quote on the heads if not I'll probably just sell them and end up going tea/tfs225
Old Mar 26, 2015 | 10:18 PM
Found an interesting article on ls1tech about the small bore heads
AFR 205's vs Trickflow 205's who has a pair? - LS1TECH
I'll be going around a high 230s to low 240s duration cam. Maybe I'll run these just for the time being until I can afford a better heads and or heads cam combo. Due to our company being relocated shortly I'd rather not blow everything I have left. Do you guys think it's possible to still make around 450+wheel through these heads? Or is it really in my best interest to sell these and just upgrade later?
Silveradorst07
Dec 31, 2015 12:04 AM
USMCvet0311
Sep 30, 2015 10:34 AM
DrX
Aug 19, 2015 04:45 PM
USMCvet0311
Jul 29, 2015 01:28 PM
black6spdz
Jul 16, 2015 01:32 AM
