forged 370 with small bore heads
Had a quick question for some of you gurus out there. I've been debating building a forged piston/rod 370 and finding some shavings im a little closer to pulling the trigger. My only dilemma is that I dropped a big chunk of change on some small bore tfs 205 comp. ported heads. I know the chamber size won't be helping anything as well as the intake runners being too small for the goals I have in mind. I mean for a temporary deal how do you think they'd do just until I can afford a set of tea/tfs 245s? Or am I better off just sending these heads out to tea for porting opening up the chambers etc I'm thinking a high compression 11.5-12:1 370 240s duration cam and possibly spraying it later on down the road.
Thanks in advance
T.J.
Thanks in advance
T.J.
Found an interesting article on ls1tech about the small bore heads
AFR 205's vs Trickflow 205's who has a pair? - LS1TECH
I'll be going around a high 230s to low 240s duration cam. Maybe I'll run these just for the time being until I can afford a better heads and or heads cam combo. Due to our company being relocated shortly I'd rather not blow everything I have left. Do you guys think it's possible to still make around 450+wheel through these heads? Or is it really in my best interest to sell these and just upgrade later?
