FI w/ Truck Manifold & # 7 Cylinder
Old Jan 23, 2010 | 11:30 PM
dirt track racer 81's Avatar
Originally Posted by MikeGyver
And with the Vic Jr. and naturally aspirated?
this was not my truck is a was a guys truck at were i used to work, it was a stock 5.3 with an sts kit on 10lbs, it actually happend after tuning (never ran lean) on road simulation on the dyno, was doing a power curve test when it let go. ending up building a forged iron ls1 out of it.
Old Jan 23, 2010 | 11:34 PM
MikeGyver's Avatar
Is your arm OK after I twisted the info out of you?
Old Jan 23, 2010 | 11:36 PM
lol it popped a few times but its all good
Old Jan 24, 2010 | 01:31 PM
SincalT/A's Avatar
I have spent a good amount of time thinking bout this #7 issue.While i do believe coolant temps are partialy responsible for problems found there.I going to go outside the box (Imagine that lol) and put the majority of the issue is in the firing order and crankshaft deflection.We should all realize the rpm's are not constant within a internal combustion engine even during wot.Cylinders begin to accelerate at diffrent rates during any given cylinders firing within the order.So in comes my theroy 1-8-7 is part of the firing order.I believe 1 loads the crank with a certain amount of energy while 8 transfers some of 1's energy +all of its own toward accelerating 7 much faster then other cylinders toward tdc.In turn causing cylinder temps to rise significally more than others.Which would put that cylinder first in line to die from preignition/detination.
OHsixLS3
Dec 27, 2016 09:30 AM
wrb002
Aug 31, 2015 12:00 PM
DrX
Jul 29, 2015 09:36 PM
black6spdz
Jul 16, 2015 01:32 AM
Hmguyton
Jul 7, 2015 03:29 PM
