Explain Block Fill to me please
Old May 8, 2011 | 07:26 AM
Gadgetized's Avatar
It isn't as bad as it sounds. You can do a "short fill", and still drive it on the street. I have a friend that did a short fill on a street 427 SBC that made 930 at the crank on juice without problems. There are actually some older industrial engines that have no provisions for cooling the cylinders down there except air cooling. Most of the heat is in the head area. I was considering a short fill when I did my 434, but ended up getting a Dart block as they are a lot better.
Old May 8, 2011 | 02:38 PM
budhayes3's Avatar
PT's Slowest Truck
The guys here have already posted everything that I know about block filler, but I did find some products via google that you may or may not be familiar with Roger. I understand that you're not considering this as it's mostly a race only type of thing and just would like to know about it to satisfy your own curiosity, so hopefully these product descriptions and whatnot will help:
http://www.hardblok.com/
http://www.moroso.com/catalog/catego...?catcode=22008
Here's some info I found courtesy of Kennedy's Dynotune, who I'm not familiar with, but the info seems sound:
Originally Posted by Kennedys Dynotune
Cylinder block fill should be considered if a large overbore must be used or very heavy nitrous use is contemplated. A complete fill makes the block unsuited to anything other than drag strip use. But a 1/2 fill or less provides some added support for the cylinders and can be used on the street. A partially filled block will run hot though. Overheating may occur and an upgraded cooling system using parts such as an electric water pump, high capacity radiator, and a better fan may be needed. Agents that promote heat transfer such as "Water Wetter" are also helpful.
Before starting any expensive block modification, the block should be checked by a competent machine shop for cracks and casting defects such as core shift. Ultimately, if extra displacement is wanted, it should be attained by installing a stroker crank and not by excessive use of the boring bar.
Besides keeping the cylinders as thick as possible, the main cap area also needs attention in the building of a nitrous/SC engine. Stock SBC with 2-bolt caps are adequate for basically stock motors with small amounts of nitrous or boost (in the 100-150hp range). As noted above, block filler will help here also, keeping in mind the potential for overheating that relates to using fill. Block filler will stabilize the crankcase webs and help prevent main cap "movement" under load. The term "movement" refers to a consequence of block flexing and if excessive this will quickly destroy the main bearings and then the crank. Highly modified small blocks will need 4-bolt main bearing caps. The stock iron 4-bolt main caps are a significant upgrade compared to stock 2-bolt caps. They are all that will be needed for typical street or street/strip use. Very highly stressed engines (>250+hp nitrous/>20psi of boost) will benefit from 4-bolt steel caps. Caps with splayed outer bolts offer only a small advantage on stock blocks. Aftermarket blocks, with reinforced webs, will benefit most from the 4-bolt splayed outer bolt steel caps.
An analogous situation exists with respect to the SB Ford. This is an excellent motor in many respects, but the stock Ford small block has significant weaknesses, even more so than the SB Chevy. Most hot rodders consider these blocks as good to only ~500-575hp range depending on the exact combo before the strength of the basic block becomes problematic. Aftermarket main caps, main stud girdles, and block fill are all options for strengthening these motors.
The deficiencies of the stock small blocks have been addressed by both GM, Ford and the aftermarket. For both Fords and Chevys, the factory and the aftermarket produce a variety of heavy duty "race" blocks. These typically are made of stronger alloys, offer thicker cylinder walls, strengthened crankcase webs, upgraded main caps, and thicker deck surfaces. All are quite advantageous when a max-effort motor is being built. In addition to accommodating larger bores, these blocks are often designed to also allow use of longer stroke cranks than their OEM counterparts. The primary downside is cost. Typically, from $1,500 and up depending upon the model chosen. However, these blocks are stronger than even a maximally prepped OEM case. And compared to the cost of fully prepping a production block, the total cost may actually be less if a factory machined race block is selected. Having a stock block fully "blueprinted" is not cheap by any means and no amount of machine work can compensate for the basic deficiencies of the OEM design.
The "new generation" of small block motors are the future of the domestic performance market. Both the Gen III Chevy and the Ford "modular" motor offer significant advances over their traditional predecessors. While most of the advancement has been in the cylinder head area, the "bottom end" and cylinder blocks of these motors also have been improved. These stronger blocks have increased potential for handling high power without resorting to extensive modifications compared to the earlier models. Cylinder wall thickness is still an issue though, so overbore should be kept to a minimum if high boost is contemplated.
Old May 8, 2011 | 10:50 PM
Spoolin's Avatar
GFYS and STFU
I didn't read Billy's link yet but wanted to add that most Top fuel dragsters and engines that run on Nitro or some form of alcohal don't need coolant passeges or cooling at all on the motors because they actually have a problem with keeping the engine warm. The exotic fuels does the opposite and actually removes too much heat from the engines. I've read stories of valves freezing.
Old May 8, 2011 | 10:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Are there different block fill products for cast iron blocks vs aluminum blocks? Or do they use the same stuff?
Old May 9, 2011 | 12:10 AM
budhayes3's Avatar
PT's Slowest Truck
That's a good question...I tried to do some searching, and it seems like all of the block fillers, as well as some shadetree techniques, work well in cast iron blocks, but there has been some difficulty getting stuff to work in aluminum blocks. The Hardblock stuff claims that "Its coefficient of thermal expansion is identical to cast iron engine blocks. Product has been tested and proven effective in aluminum blocks." Which to me translates as "Works in iron blocks, may or may not work in aluminum blocks"...but that's just the way I read it
Top Fuel dragsters have aluminum blocks, wonder what they use? (and how much is costs!)
I did find that some ricers are fond of a product called "Devcon" for their aluminum blocks...
Found some more info, nothing too technical, and it seems like everything in this article has been addressed in this thread, but it's a quick read (shorter than some of my posts )
http://www.carcraft.com/techarticles..._question.html
After reading this thread and thinking back, I now remember seeing blocks at my dad's shop that have been filled...I should ask him about this also. Guess that I should start making a list and writing down the questions that I have for him lol, I'm starting to lose track
Old May 9, 2011 | 01:09 AM
Get him to sign up and participate here on PT.net! Then we can just ask him!
Old May 9, 2011 | 02:17 AM
budhayes3's Avatar
PT's Slowest Truck
LOL, I've seen my dad mess around on a few forums...good thing his engines are faster than his typing skills
I'd love to see my pop hanging on this site, actually he has an 06 Chevy dually to tow his race car, and a 96 Blazer just like me (actually he gave me mine ). Dad has some negative opinions about internet misinformation unfortunately though, and is busy as hell. Maybe when he retires he'll have more time to hang with us, in the mean time I'll have to be the middle man
Old May 9, 2011 | 01:45 PM
nonnieselman's Avatar
Devcon works great for bedding a rifle stock/action also
Guys around here use concrete dust mixed with some type of sand, pour it in the blocks after they mix water and another chemical. Drys somewhat quick. and they rev them too the moon. One guy has a 502 in a dirt drag truck that revs 10k.. it sounds awesome!
Old May 11, 2011 | 06:13 PM
Flaco's Avatar
8 Second Club
its basicly to strenthen the block, we used it back with the 414 on the hayhauler, because we cracked one sleeve once...we half filled it, so we could still run coolant through it, u can still drive the vehicle as long as u have a really good engine oil cooler to keep temps down..
Old May 11, 2011 | 06:43 PM
Thanks for the reply Flaco.
So with a very good oil cooler and the rest of the cooling system in check, street driving would still be possible. I'm sure towing would be out of the question, and likely daily driving as well.
calsdad
Jun 14, 2023 11:07 PM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
