Engine Swap Question
Old Feb 16, 2022 | 08:23 PM
luismontelongo's Avatar
Default Engine Swap Question
I just did an engine Swap from V6 to V8 the tachometer is now showing a little higher about 400 rpm more. The truck is an 05 Silverado any suggestions?
Old Feb 16, 2022 | 09:19 PM
RDF1's Avatar
DuNnO
5 Year Member
Does the needle go to zero with the key on /engine off?
Old Feb 17, 2022 | 05:37 AM
B52Bombardier1's Avatar
You likely need a slight tuning adjustment to the operating system inside your Powertrain Control Module or Transmission Control Module, however your vehicle is equipped. It is also quite possible that it really is running 400 RPM higher and you can adjust the idle RPM down a little . . . . . ?????
Rick
Old Feb 17, 2022 | 08:31 AM
Pennywise67's Avatar
5 Year Member
put a scanner on it and see if the RPM matches the Tach.
Old Feb 22, 2022 | 08:49 AM
I'll be putting a scanner to it today to see if it is matching
Old Feb 22, 2022 | 04:01 PM
RedXray's Avatar
100% Redneck
Check to see if the the Tach Output is been corrected from output "4" for the V6 to "3 or 6" for the V8 in HP Tuners
cornief
14
Nov 7, 2022 11:30 AM
gonzo 6.2
Jun 13, 2005 08:33 AM
