Engine power reduced 6.2 cheyenne
Old 03-31-2018, 05:27 PM
Registered User
Cheyenne09's Avatar
Default Engine power reduced 6.2 cheyenne
I have a 2009 cheyenne single cab originally a 5.3 but i replaced it with a 6.2/6l80 with 4x4 transfer and front diff but engine power reduced message keeps coming up replaced acceleration pedal had it programmed and still keeps coming up. Any advice as to what it can be any ideas, thanks in advanced!!
Old 03-31-2018, 05:36 PM
FFDP's Avatar
Is it tuned for the 6.2 swap?
Did you use the donor motor's computer or tune the factory computer for the swap?
REP mode triggers specific codes, what are they?
Old 03-31-2018, 06:34 PM
Registered User
Cheyenne09's Avatar
yes donors computer and it is tuned for what it has it has a couple bolt ons but at first it read the throttle body code had it cleaned with carb cleaner and worked for a while then happened again with the pedal sensor code this time, replaced it and worked for a while then happened again
Old 04-01-2018, 12:11 PM
TXsilverado's Avatar
I have a used TAC module from an 04 tahoe ill sell for $35. I also have a shaners ported throttle body i dont need. That would cover a possible bad TPS and still get more performance if it isnt the issue.
Also clean your grounds on the back of the driver's head and the block on the passenger side. Check the connection at the ring terminal on the back of the block on the pass side. The cable is known to break but the terminal holds in place because its crimped over the insulation. They are a **** to get to. There is also a ground on the frame below the driver's door. To check too.
Is it a p code, or U0107?
Old 04-01-2018, 12:24 PM
03sierraslt's Avatar
09 and 04 use different computers, throttlebody and controller.
Old 04-01-2018, 02:44 PM
I wish it was easy to convert to cable...
Old 04-01-2018, 05:49 PM
I Did......
Old 04-01-2018, 06:07 PM
madmann26's Avatar
There's an option in the System portion of the tune that denotes what is DBC vs DBW.
1=DBW
0=DBC
Old 04-02-2018, 01:02 PM
so If worse comes to worse, I can install a cable throttle body, and get a new gas peddle and make only one change in the tune?
Old 04-02-2018, 09:00 PM
Custm2500's Rude Friend
1FastBrick's Avatar
No!
Use a Van OS for your year.
Quick Reply: Engine power reduced 6.2 cheyenne
