Engine painting
Old Apr 19, 2014 | 07:53 PM
TURBHOE's Avatar
Default Engine painting
This might be the wrong place but I'll ask any way.
I've been trying to get this iron block ready for paint but it seems to rust as fast as I can sand. So I said screw it and got some rustoleum rust converter stuff. Applied it wil a foam brush and it looks good now. How ever it says if your going to paint with oil based paint to do so in 4 hours. But if your using lacquer or aerosol paints to wait three days. Any body know why?
On a brighter note I got my bearing clearances all done up today so I can build it once it's finally painted.
Old Apr 21, 2014 | 08:05 PM
NuckenFuts's Avatar
I used a wire wheel on a drill/break clean and then primed and painted mine with engine paint from a rattle can same night. Im sure not best way but think it turned out OK. Sounds as if it leaves some stuff on the block that might eat the paint. I'm sure you can break clean it off.
Old Apr 21, 2014 | 10:07 PM
stroker87's Avatar
i just cleaned mine really good wiped it sown with rubbing alcohol and applied VHT engine paint its held up pretty good other then it flaking off the freeze plugs
Old Apr 28, 2014 | 09:42 PM
SumtinCoo's Avatar
I just took a wire brush attachment on a cordless drill, dipped the brush in paint thinner and went to town on the block. Painted it with dupicolor engine enamel primer, then gloss black. Turned out pretty good but hasn't been off the stand yet so no wear and tear on it yet.
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Sep 30, 2015 10:34 AM
