engine break in
Old Nov 30, 2006 | 10:24 PM
Sharadon's Avatar
All my engines get broken in on the Dyno. With a solid lifter cam the first 15 mins @1800 rpm allow for cam breakin. Quick check of the lash, then WOT pulls start. For roller motors just a warm up, check lash, then WOT.
The rings need load to breakin properly, It usually takes 4-5 pulls to get the rings in.
Properly built engines are best broken in fast. No need to play around breaking it in nice.
Old Dec 1, 2006 | 06:54 PM
TURBHOE's Avatar
so what if you do a new tranny at the same time? should you beat the **** out of the tranny too?
Old Dec 1, 2006 | 07:00 PM
nightrunner's Avatar
Mr. Obvious
well flt has told several members the proper way to break in their trans is to do a burnout out of their driveway
Old Dec 1, 2006 | 07:09 PM
TURBHOE's Avatar
thats one way to do it lol. never had a rebuilt trans so wasn't sure.
Old Dec 1, 2006 | 10:09 PM
05crew's Avatar
if the tranny goes in drive and rev. and shifts good in the first 400 ft. then then stop and mash that bitch!!!
Old Dec 2, 2006 | 10:54 AM
joehawkz71's Avatar
lol.... people just like to beat on there **** here... i figure if your going ot baby it your whole life that go easy on the break in.....but if you want ot have fun with it then beat the **** out of it....
and for the tranny...just make sure it shifts fine at first like stated above and then give her hell!
Old Dec 4, 2006 | 05:24 PM
GMGen3's Avatar
As for my humble .02 --->
I was taught to break in the engine in steps. First, the cam (unless roller). Usually the cam manuf. will specify. Next, seat the rings. Put the trans in a manual range and hammer down! Run the rpms up and let off, using the trans to slow the vehicle. In theory, this achieves max. engine vacuum and allows the cylinders/rings to cool. Repeat this like 10 times. The bearings should be fine if you haven't already spun one.
As far as the trans goes, I like to drive it a little just to make sure that there aren't any obvious problems before I kill it (I don't have a dyno, duh). If you buy a trans from a specialist like FLT, they have already dyno'd it and given it their seal of approval long before they turn you loose with it, so give that ***** hell!
I know, seems like a bunch of but that's what I've always practiced and it seems to work for me.
Choda
Jan 22, 2026 02:03 PM
Oobray
Jun 13, 2022 03:38 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GMCtrk
Jul 9, 2015 08:26 PM
