Edelbrock 2215 cranking compression?
Old Jun 2, 2015 | 01:19 PM
Forcefed86's Avatar
8 Second Club
Default Edelbrock 2215 cranking compression?
Just installed one of these in a 4.8. Wondering what kind of cranking compression people are seeing with this cam. I had to adjust the timing set quite a bit to hit the card. I managed 1 degree retarded from the card, but I'm only seeing 145psi or so of cranking compression. Last year I ran the isky triple 12 and saw around 160. Curious if this is "normal" for this cam.
The 4.8 was a spare motor and I sold the trip 12 last year. I was looking for a mean idle, low overlap cam that would work "OK" with mild boost. So I tried the edelbrock 2215. Figured I'd try putting this in the truck section because I see these cams primarily run by the truck crowd.
Edelbrock is a 220/220 @ 111 .510 lift.
Tripple 12 was a 212/212 @ 112 .565 lift.
Sounds mean anyway!
Old Jun 3, 2015 | 12:59 PM
terravast4's Avatar
nice set up
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Velocity1
Oct 2, 2015 08:01 AM
