Which dot to set timing straight up on rollmaster crank gear?(pic)
Old Dec 3, 2006 | 12:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Which dot to set timing straight up on rollmaster crank gear?(pic)
The cam gear only has one dot, the crank gear has two. One dot is right above the keyway which is the one I think I should use and the other is right by the teeth and is about 2*s advance. Here is a pic I think I need to install it with the dot that is right above the keyway. If I do that which dot do I line up with the dot on the cam gear?
Old Dec 3, 2006 | 01:06 PM
Rhino79's Avatar
9 Second Club
I think you would line up the dot on the tooth....no 100% though.
Old Dec 3, 2006 | 01:14 PM
kbracing96's Avatar
what do the directions say?
Old Dec 3, 2006 | 01:22 PM
moregrip's Avatar
what a rush!
Richard from WCCH knows, give him a shout
Old Dec 3, 2006 | 01:37 PM
1slow01Z71's Avatar
The instructions are very vague and they dont clear up which dot to use to install it straight up. I got it figured out though, I posted this thread on tech and Predator-Z confirmed what I thought is the proper way to install it.
Old Dec 3, 2006 | 01:38 PM
1slow01Z71's Avatar
Im putting the motor back together today
Ill call and confirm with him Monday, and I need to order a few more parts from him.
Old Dec 3, 2006 | 02:31 PM
Richard@WCCH's Avatar
FormerVendor
Lineup the dot on the gear teeth.
Richard
Old Dec 3, 2006 | 03:28 PM
Quik's Avatar
5 year bitches!
i go off the teeth gear
chopperloco
Jul 10, 2016 10:45 PM
Blwn99x
Aug 2, 2015 09:51 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
jmarkway
Jul 18, 2015 09:23 PM
GreyChevy
Jul 7, 2015 08:57 PM
