does this intake fit on 6.0L?
well i found this intake and was woundering if it fits and whats size injetors does it have?
You are bidding on a complete intake manifold assembly that will fit any of the Gen III GM truck engines but is designed for the 2009-10 5.3 and 6.0 engines. It has zero miles and has never been bolted to an engine. It is the cathedral port design, note this takes the latest MAP sensor. Includes the manifold, gaskets, bolts, DBW 88mm throttle body, fuel rails, injectors plus more.
Looks very expensive since its missing the evap and MAP sensors.Just the map sensor is over $150 from GM....
Also need a part # before we can tell you what the injectors are....
ARC
57
Feb 21, 2022 10:54 AM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
oharajo
Jul 18, 2015 09:24 PM
