Do they make an adapter bracket for 90 TB nbs intake manifold?
Old Apr 19, 2013 | 12:58 PM
Camin00's Avatar
Default Do they make an adapter bracket for 90 TB nbs intake manifold?
found a junk yard with a ton of 90mm cable throttle bodies. do the make an adapter for the nbs intake manifold?
Should I just go ahead and get the nnbs intake manifold? What are typical power gains on a 01 5.3L
Old Apr 19, 2013 | 01:08 PM
nonnieselman's Avatar
unless you have some fancy heads and big cam, i doubt your goin to see a significant difference.
Old Apr 19, 2013 | 01:09 PM
DTHPROOF's Avatar
You need a 4-bolt throttle body with a 90mm opening. GM has never made one cable-driven. They're all DBW.
Old Apr 19, 2013 | 01:17 PM
Camin00's Avatar
Drive by wire is the NOT the electric one correct?
Just milled heads and 210/218 .584 .584 116lsa
Old Apr 19, 2013 | 01:21 PM
Drive by Wire is electronic - DBW
Drive by Cable is mechanical - DBC
IM not saying it wont help, but i dont think your goin to be happy for the money spent vs power gains.
Old Apr 19, 2013 | 01:33 PM
DTHPROOF's Avatar
I bought the TBSS intake BRAND NEW and complete with rails/injectors for $175, a PTM 92mm dbc TB for $350, injector adapters for $96, and I still have to buy the corvette fuel pressure regulator to make the TBSS intake work. If I wasn't dropping the 6 liter in it I wouldn't even do the swap. I'll be in it for over $600 when done for about 15rwhp that I won't even feel.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
fat tony157
Jul 16, 2015 12:35 PM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
