wanna build a street truck
Old Apr 18, 2013 | 09:40 PM
Prolong's Avatar
Default wanna build a street truck
just something I can run off 91 pump gas and could be use a daily. I currently have a 5.3 silverado with 170k miles and I never really built anything before as Im new to this. Looking on a good street setup like cams and heads and pistons. I dont think I would have to go all the way to the buttom end would I? also I want to run a decent supercharger if it is possible. And Also I got a spare 6.0 block should I use that and upgrade that? and if I do would I have to get a 4l80e trans? what should be done to that and what gear ratios 4.10? Sorry I'm a noob any help is appreciated. Thanks
Old Apr 18, 2013 | 11:47 PM
oakley6575's Avatar
Get to reading. There is a lot of good info on this site. What are your power goals and what is your budget?
Old Apr 19, 2013 | 12:01 AM
silverz28camaro's Avatar
I would build the 6.0 ...
What type of truck ? lifted, lowered? 4x4?
Old Apr 19, 2013 | 02:26 AM
Spoolin's Avatar
GFYS and STFU
What's your budget and goals?
Old Apr 19, 2013 | 06:15 AM
D.J Vasquez's Avatar
build the 6.0!! when u do make sure u redue the tranni and rear gears !! they will be next to go !! like the other guy said !there is a lot of info on here !! good luck and dont forget to post build !! we love pitchers !!
Old Apr 19, 2013 | 08:51 AM
Camin00's Avatar
Start off with longtubes pacesetter are the best for a budget. exhaust CAI and tune to start. you will be pretty impressed with the difference with just these 4 upgrades
Start off with external things that will work with a 5.3L and 6.0L
Old Apr 19, 2013 | 11:11 PM
Prolong's Avatar
Well id rather build the 6.0 jus want something quick but still be able to dd as budget goes if i do the 6.0 ill work on it while its out of the truck so ill work on it slowly along with trans and rear end
stealthperf
34
Feb 14, 2016 11:35 AM
wrb002
Aug 31, 2015 12:00 PM
USMCvet0311
Aug 14, 2015 10:28 PM
BennyB
Aug 1, 2015 08:48 AM
black6spdz
Jul 16, 2015 01:32 AM
