Do I need Vacuum?
I've been having issues since I put my cam in. I kinda had it sorted out untill my TPS problem reared its head. So when AJ gets back we'll fix that with the MAP perameters. So now my question. If I dont let the truck run for about a minute or so (cold or hot) and I step on the brake to put it in gear, it acts like it is starving for vacuum and kinda studders at idle. Some times if I just ignore it and get to the stop light about 300 ft from my drive way it'll do it some more and if I ease of and on the brake it goes away. So do I need a vacuum canister or what do I need? please help, I love my truck but its annoying to drive at the moment
Since I have a similar cam and same size motor I think I might be able to help... You need to adjust your Desired Idle Airflow table and your Throttle cracker table and maybe throw a degree or two in you base timing table and add like 50-100 rpm to the idle rpm speed table.... Mine did the exact same thing until I tuned it, it is much better now almost like stock, still need to do a little more tweaking but it has not died on me yet since I tuned it... Unfortunetly there is really nothing you can do until you tuner gets back, at least in my opinion....
yeah, ur very correct. And Im glad to see u didnt do the 'gina sized cam haha how do u like it? I do know I need to probly adjust the IAF table, Kyle took a bunch of timing out when we went to the track but I didnt get a chance to run it again cuz some *** whipe dumped oil for the second time that night. But maybe that fucked with it. I've got alot of stuff to play with
I need to get an AFR gauge I think as well. Has anyone heard about the ones that feed directly in to the PCM??
I hear that. I took my truck out the other day and long story short that night I ended up racing my girl's friends 350Z again.. Hah, lucky me everything just clicked in my truck, I hit it at about 25 after the left hander to get on the freeway and I had about 3 lengths on her til I let off at about 110. She proceeded to do 140, haha ricer fly-by included
yeah if your still at stock idle that would be an issue, I was just about to put a cam in my camaro and most that put larger cams in had to raise their idle to 700-900rpms depending on lobe seperation and such
Wow that high? Mine is sitting at 575-600rpm, but my cam is not huge or anything...
