Did I mess up?
Old May 16, 2015 | 09:22 AM
shortpump's Avatar
Registered User
Default Did I mess up?
I bought a set of 706 heads yesterday for my 5.3. They have been ported, polished, and shaved .060 (yes thats 60 thousandths).
Did I mess up and is this too much milling? or is there a way I can compensate with head gaskets or something?
Old May 16, 2015 | 01:00 PM
Atomic's Avatar
I have a gauge for that
Its hard to say because it depends on your cam profile greatly. Best way to tell is to install the head and check piston to valve clearance.
Old May 16, 2015 | 01:07 PM
shortpump's Avatar
Registered User
My plan is to put a cam in while doing the heads. any suggestions?
Old May 16, 2015 | 01:19 PM
Atomic's Avatar
Put the cam in, install 1 of the heads with a factory gasket and a couple of the bolts (dont need all of them). Check your PTV clearance. If its not enough or you have contact you can either have custom gaskets made (about $300 for a pair), flycut your pistons, or get different heads.
Old May 18, 2015 | 12:09 PM
53bowtie's Avatar
Another option would be to have a custom cam ground specifically for those heads. It usually doesn't cost much more if any for a custom grind than an off-the-shelf grind.
Another issue I have heard of people having when milling heads past 0.040" is getting the intake bolts to line up and the intake gaskets to seal completely.
Old May 19, 2015 | 02:48 PM
shortpump's Avatar
Registered User
A custom grind wouldn't be bad if i knew what numbers to look at and select how I want it done.
dantheman1540
Feb 24, 2016 09:56 PM
drummer0415
11
Oct 24, 2015 08:16 PM
MikeD.
Oct 13, 2015 08:08 AM
97_ek
Sep 23, 2015 09:16 PM
cousblake11
Sep 9, 2015 06:52 PM
