Did The Cam Today
Old Sep 2, 2005 | 03:44 PM
BLACK 5.3's Avatar
Default Did The Cam Today
WOW this is the most fun i had since the radix install did the cam and springs in like 6 hours everything went on so smoothly and its not as hard as i thought it would be.
i have an lq4 sitting on a stand so it made this job alot more fun
at first i was not so sure that i could swap the springs my self but it was so easy i couldnt believe it... best way to swap spring would be to find top dead center just stick something in the sparkplug hole then turn the crank till you feel the piston is at the top then remove the two springs for that cylinder..
Old Sep 2, 2005 | 05:30 PM
SSlow 4.8's Avatar
6 hrs isnt bad for doing it by yourself... its always satisfiying knowing that your truck is performing better bc of a mod YOU did and YOUR hard earned money bought.
What kind of cam was it?
Old Sep 2, 2005 | 05:48 PM
BLACK 5.3's Avatar
haha yeh its satisfying knowing that your driving a truck that you urself worked on
the cam is the 045 cam... 216/224 from vinci performance.
Old Sep 2, 2005 | 05:53 PM
SSlow 4.8's Avatar
sounds good...well keep up the good work and good luck.
Old Sep 2, 2005 | 06:16 PM
BLACK 5.3's Avatar
thanks bro.
man im diying to know how much power this 6.0 with this cam and radix going to make in my rcsb
ill get some dyno runs in a week and ill post them for ya
Old Sep 2, 2005 | 07:19 PM
BigBlockChev572's Avatar
Cheater, you're supposed to do it with the motor in the vehicle so you can share your horror stories! J/K
Pretty cool you did it on the stand, sounds like a sweet project, keep us updated!
Philip S.
Old Sep 2, 2005 | 07:32 PM
white1's Avatar
Wish I would have had a stand for my 3 in two month cam swaps!!
Old Sep 3, 2005 | 10:41 AM
BLACK 5.3's Avatar
DUDE 3 cams in 2 months wow what size? and what did you finally go with did you go bigger or smaller after the first one????????????
Old Sep 3, 2005 | 01:41 PM
Whistle Truck Guy
Philip S.
I did the cam swap in mine with the engine in it... Wasnt too bad still, just got coolant and tranny fluid everywhere. Took me a little longer than it should have tho... I'd never messed with an LS1 style engine before, so I just assumed they were designed similarly to the old 350's in that maybe the lifters were accessible under the intake and valley cover. HA! Wasted a good amount of time doing that crap I could have spent doing something worthwhile.
Old Sep 3, 2005 | 05:48 PM
Yeah, mine wasn't bad. That oil pump (lining it up and pick up tube o-ring was the worst) , dropping the pick up tube bolt in the pan and losing my keepers. It sucked because the local dealership didn't have them in stock, so a lot of time was wasted. I also thought I could access the lifters when pulling the intake a while back. Wish it was that easy
Philip S.
DrX
Aug 19, 2015 04:45 PM
USMCvet0311
Aug 13, 2015 09:59 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
