details on the 5.3 high output???
Old Oct 4, 2008 | 07:30 PM
mred's Avatar
Default details on the 5.3 high output???
anyone have any in put in the 5.3 H.O. motor.
what makes it such a H.O.
plus the HP levels to 335-345 i assume.
what could i do to a regular 5.3 to do the same.
thanks
Ed
Old Oct 4, 2008 | 07:33 PM
viciousknid's Avatar
Where's the Beef?
Exhaust and tune will get you there. add a came too and you'll be there at the rear wheels.
What makes the 5.3 High Output crate engine so special is that the GM engineers have added a GM Performance Parts custom cam and Grafal-coated pistons. With these simple upgrades, the 5.3 HO kicks out 332 horsepower and 352 lb.-ft. of torque. And, just like the stock 5.3, the 5.3 HO is capable of thousands of miles of dependable service while returning outstanding fuel mileage, thanks to the superior design of the LS Family of engines.
Old Oct 4, 2008 | 07:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
are we talking about the Aluminum block L33 5.3LHO? There are a few threads on the subject. Flat top coated pistons, 243 heads make up the major differences. cam and tuning.
Old Oct 4, 2008 | 07:59 PM
mred's Avatar
not sure. i didnt know there was a 5.3 alu. motor.
i ran across a 5.3 H.O. and i seen the hp out put and i was in shock.
i had no clue of a 5.3 STOCK from G.M. making those numbers.
i have been looking at a 5.3 or 6.0 to swap into my truck.
the 5.3 gets good MPG. i will assume the H.O. does to???
i can buy 5.3s ALOT cheaper than i can a 6.0
Old Oct 4, 2008 | 08:52 PM
trever1t's Avatar
yeah, mine is the L33. Converting to flattop pistons and the heads will cost more than just buying the 6.0
Old Oct 4, 2008 | 08:58 PM
mred's Avatar
so why did you spend "more money"
versus going to the alum.5.7 or the 60lbs more 6.0?
Old Oct 4, 2008 | 09:23 PM
trever1t's Avatar
came with my truck
Old Oct 4, 2008 | 10:34 PM
ForcedTQ's Avatar
came with my truck
Yeah, he didn't have to do a damn thing to it.
Until he found this site, and now I see what he has done to his truck along with the times he's getting and am trying to get mine set up to at least run in the 12's.
Bumpers
Aug 4, 2024 09:44 PM
LCHEE
Oct 24, 2020 04:10 PM
Zizzle
Oct 19, 2017 08:44 PM
Silveradorst07
Sep 2, 2015 12:55 PM
JordanH
Aug 8, 2015 07:59 PM
