Compression ratio question
Old Apr 4, 2011 | 08:28 AM
Rhino79's Avatar
9 Second Club
Default Compression ratio question
My 09 4.8 has the 243's and I have been researching cams, and trying to calculate how much to mill my heads and what gasket to run for optimum static and dynamic comression ratio. I always was under the belief that the 4.8's and 5.3's from 99 were 9.5:1. I found a spec sheet that says my engine is 9.1:1??
http://www.gmpowertrain.ca/Product/4...Y2%20Specs.pdf
So with that being said, I will likely end up milling the heads .035~.045" depending on what gasket options there are. I have see plenty of LS1 gaskets with a 3.9ish bore, but is there a small bore gasket for the 4.8's and 5.3's in a .040" thickness? I want to try and get the SCR to about 10:1 and the DCR to about 7.5~8ish.
Any input greatly appreciated!!
Old Apr 4, 2011 | 12:17 PM
Phantom's Avatar
11 Second Club
the cometic .040 3.91 gasket will work
Old Apr 4, 2011 | 02:33 PM
Rhino79's Avatar
9 Second Club
Yeah, thats probably what I'll go with. I was hoping there was a gasket with a lil smaller bore that would help with the cr.
Old Apr 4, 2011 | 02:37 PM
Phantom's Avatar
11 Second Club
even if you could find a gasket that was 3.8 bore the difference is compression is only ~.05 from a 3.91 using .040 thickness. call cometic up. they can make you any gasket you want for the same price.
Old Apr 4, 2011 | 06:08 PM
05gmcsierra's Avatar
I just don't get how its 09.1:1 my truck 799 heads and flat top pistons came with 9.9:1
Old Apr 4, 2011 | 09:23 PM
Rhino79's Avatar
9 Second Club
I don't know man, but just milling and bumping the cr how it sits would be a signifigant bump in throttle response and grunt.
Old Apr 4, 2011 | 10:52 PM
Its a well noticeable difference when I milled my heads I went from 9.9-10.5 and put the 217/223 over the 212/218 and I went from 8.97-8.62 on the 1/8 mile.. and with same tune...
blownss27
Aug 14, 2020 08:27 AM
03regcab sierra
Sep 9, 2015 02:02 PM
Alco
Sep 4, 2015 04:08 PM
Tigger Welder
Sep 2, 2015 08:17 AM
USMCvet0311
Aug 1, 2015 07:45 AM
