Compression ratio question
My 09 4.8 has the 243's and I have been researching cams, and trying to calculate how much to mill my heads and what gasket to run for optimum static and dynamic comression ratio. I always was under the belief that the 4.8's and 5.3's from 99 were 9.5:1. I found a spec sheet that says my engine is 9.1:1??
http://www.gmpowertrain.ca/Product/4...Y2%20Specs.pdf
So with that being said, I will likely end up milling the heads .035~.045" depending on what gasket options there are. I have see plenty of LS1 gaskets with a 3.9ish bore, but is there a small bore gasket for the 4.8's and 5.3's in a .040" thickness? I want to try and get the SCR to about 10:1 and the DCR to about 7.5~8ish.
Any input greatly appreciated!!
even if you could find a gasket that was 3.8 bore the difference is compression is only ~.05 from a 3.91 using .040 thickness. call cometic up. they can make you any gasket you want for the same price.
03regcab sierra
Sep 9, 2015 02:02 PM
