Comp Hi-Tech vs. Magnum Pushrods
Old Oct 19, 2008 | 02:11 PM
SlvrSierra4.8's Avatar
Default Comp Hi-Tech vs. Magnum Pushrods
I need a set of hardened 7.4 pushrods. What are the differences between the Comp HiTech and Magnum pushrods and which do I need for a standadrd 7.4 hardened pushrod replacement when doing a cam swap?
From the research I have done it looks like Comp # 7955-16 is what I need, but I just want verify it in advance. Also where are you guy's picking yours up from, TIA-
Old Oct 19, 2008 | 06:11 PM
cricket....cricket....
Old Oct 19, 2008 | 06:23 PM
ap2002's Avatar
im pretty sure that the hi-tech ones are the ones you need...
Old Oct 19, 2008 | 07:13 PM
hirdlej's Avatar
The hi-tech's are lighter weight, have more precise radii and are all around a better pushrod. I used the hi-tech's in my 6L, magnums in my 454. Is there really a measurable difference? Probably not that you'll notice. But are the hi-techs better? Yes.
Old Oct 19, 2008 | 07:46 PM
cool thanks for the info, will have to pick up a set soon
JordanH
Nov 6, 2015 07:42 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Velocity1
Oct 2, 2015 08:01 AM
jtphelps289
Sep 30, 2015 09:26 PM
