comp cam valve springs 26926
I would stay away from anything that Comp sells except for their camshafts (which happens to be the only thing that they actually still manufacture at Comp as opposed to outsourcing to the lowest bidder). PAC, Manley Nextek, and Crane have proven to have reliable springs that perform as designed.
i could show you some serious carnage after about a hand full of heat cycles that the 926s did to my engine
id never use a comp spring again, whats even worse they damn near begged me to use them cause they were so perfect to my setup, i got a brand new set if you want them
