comp cam valve springs 26926
Old Nov 23, 2011 | 08:21 PM
ou812sm's Avatar
Default comp cam valve springs 26926
Are these any good
Old Nov 26, 2011 | 12:19 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by ou812sm
Are these any good
I would stay away from anything that Comp sells except for their camshafts (which happens to be the only thing that they actually still manufacture at Comp as opposed to outsourcing to the lowest bidder). PAC, Manley Nextek, and Crane have proven to have reliable springs that perform as designed.
Old Nov 26, 2011 | 01:22 AM
SweetS10V8's Avatar
Ive run 926s on many things, without an issue. Including some extremely harsh setups and they have always worked without fail.
Old Nov 26, 2011 | 02:02 AM
dmelvin's Avatar
There are several threads if you search for them about Comp 918's ruining motors. As far as their dual springs, I have no clue.
Old Nov 26, 2011 | 07:50 AM
skeet's Avatar
i could show you some serious carnage after about a hand full of heat cycles that the 926s did to my engine id never use a comp spring again, whats even worse they damn near begged me to use them cause they were so perfect to my setup, i got a brand new set if you want them
Old Nov 26, 2011 | 08:46 AM
1989k1500's Avatar
A lot of people have run 918s without issue too, but I just couldnt see risking it.
I was going to mention your truck in here.
Old Nov 26, 2011 | 02:48 PM
jrmchevyman's Avatar
I would probably stick with PRC, Patriot, PSI, Crane, Manley, Pac springs.
You just never know with any springs, but I would worry less with the above.
chopperloco
Jul 10, 2016 10:45 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
