Cleaning deck surface for head gasket.. Is this clean enough?
Old May 31, 2014 | 09:19 PM
Relentless07Silv's Avatar
Exclamation Cleaning deck surface for head gasket.. Is this clean enough?
Hey guys I have my heads off prepping the block for new head gaskets and Head Studs I wanted to see if I have the deck clean enough or if I should keep going. I have used a scotch brite pad and simple green to clean the deck along with a razor a bit to scrape some places while using a shop vac and napkins in the lifter trays to keep gunk from getting everywhere. All advice is appreciated.
Old May 31, 2014 | 09:40 PM
TXsilverado's Avatar
probably. i like mine spotless though. 3m rolec pad. i use the green plastic one.
before:
after:
Old May 31, 2014 | 09:43 PM
BlackGMC's Avatar
Resident Retard
I with him^^^^^. I used the same pad and it works wonders.
Old May 31, 2014 | 09:46 PM
Yea I was looking to get one of those roloc discs, seems to be alot easier. Should I pull the lifter trays and lifters out? I have heard about people running oil through the lifter valleys after to make sure no particles get in the engine. Should I do that or should I just wait to start up and start the engine and change the oil repeated a couple times?
Old Jun 1, 2014 | 02:53 AM
remove the lifter tray and stuff rags down. compressed air to get rid of any little stuff.
Old Jun 1, 2014 | 03:07 AM
1FastBrick's Avatar
Custm2500's Rude Friend
So it appears to only be a 2 beer process to to clean both side's.
Old Jun 1, 2014 | 04:23 AM
yes, it's a 2 beer job.
Old Jun 1, 2014 | 09:45 AM
Chevy_King1500's Avatar
Stu, what did you use to clean the piston tops?
Old Jun 1, 2014 | 02:07 PM
some ing i cleaned the deck surface with. 3m roloc pad.
Old Jun 1, 2014 | 02:18 PM
GMCtrk's Avatar
cRC gasket remover, a rag and a razor for me. Works fine for stock Mls gaskets.
Your deck doesn't look clean enough in the pictures posted.
