choppy cam for 5.3
Old Nov 4, 2010 | 04:21 PM
mr mississippi's Avatar
Default choppy cam for 5.3
i have a 5.3 that i wanna cam and install headers. also i don't really want to change the converter but if i have to i will. its a daily driven 2000 yukon i want a real choppy sound lsa 112 or lower but with a good power band for daily driving. was thinking a thumper cam but i've heard different opinions about it. what would be a good cam to use and i will change valve springs to match cam
Old Nov 4, 2010 | 04:29 PM
Nicksilverado's Avatar
check out the sponsers on the right >>>> texas-speed and performance has a lot of cam selections..
Old Nov 4, 2010 | 11:05 PM
budhayes3's Avatar
PT's Slowest Truck
A cam with a real choppy sound will have a lot of overlap and a higher powerband, which will require a higher stalled converter to not be soggy down low. You need to decide which is more important to you, performance and driveability or sound, you can't have it both ways.
Old Nov 4, 2010 | 11:35 PM
Dbyers2's Avatar
formery SilverSleeper1500 (12-06-2011)
I have the thunder racing TR 220 112 lsa in my 5.3 and it sounds sick with longtube Headers, been kicked off the beach 4 times for noise
Old Nov 5, 2010 | 02:34 PM
00Silv4.8's Avatar
^^ 220's sound good, even meaner with LT's. My truck has a 220 in a 4.8 so should lope like crazy, It may be on a 114 for how high my power band is and thru stock manifolds it sounds pretty decent.
Old Nov 6, 2010 | 10:00 AM
Bigschwerm's Avatar
I was thinking of swapping my Vinci Trucker cam ground on a 110 for a TR220 but I'm not sure if the power gain with be worth it or noticeable....
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
06 4.8
Jul 15, 2015 07:17 PM
